Linear time-invariant discrete delay systems in Laguerre domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2022
The paper provides the formulae connecting the Laguerre spectrum of the output signal of a linear discretetime time-invariant system to the Laguerre spectrum of its input signal and presents a standard state-space system description. The Laguerre domain system representation is meaningful when the input signal is square-summable and the system is stable. A certain type of polynomials arising in the evaluation of the output spectrum due to the presence of time delay is defined and key properties of these are investigated. The polynomials are characterized by a three-term recurrence relation that also facilitates their numerically reliable calculation.
ieee_ac20.pdf (154.06 Ko) Télécharger le fichier
hal-03323475 , version 1 (21-08-2021)
Alexander Medvedev, Viktor Bro, Rosane Ushirobira. Linear time-invariant discrete delay systems in Laguerre domain. IEEE Transactions on Automatic Control, 2022, 67, pp.2677 - 2683. ⟨10.1109/TAC.2021.3096927⟩. ⟨hal-03323475⟩
28 Consultations
156 Téléchargements
