A coupling between integral equations and on-surface radiation conditions for diffraction problems by non convex scatterers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics Année : 2021
The aim of this paper is to introduce a coupling procedure between surface integral equation formulations and On-Surface Radiation Condition (OSRC) methods for solving two-dimensional scattering problems for non convex structures. The key point is that the use of the OSRC introduces a sparse block in the surface operator representation of the wave field while the integral part leads to an improved accuracy of the OSRC method in the non convex part of the scattering structure. The procedure is given for both the Dirichlet and Neumann scattering problems. Some numerical simulations show the improvement induced by the coupling method.
CouplingOSRC:BEMPaper.pdf (389.03 Ko) Télécharger le fichier
hal-03327881 , version 1 (27-08-2021)
Saleh Mousa Alzahrani, Xavier Antoine, Chokri Chniti. A coupling between integral equations and on-surface radiation conditions for diffraction problems by non convex scatterers. Mathematics , 2021, 9 (18), ⟨10.3390/math9182299⟩. ⟨hal-03327881⟩
62 Consultations
57 Téléchargements
