A Gradient Sampling Algorithm for Stratified Maps with Applications to Topological Data Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming Année : 2023
We introduce a novel gradient descent algorithm refining the well-known Gradient Sampling algorithm on the class of stratifiably smooth objective functions, which are defined as locally Lipschitz functions that are smooth on some regular pieces—called the strata—of the ambient Euclidean space. On this class of functions, our algorithm achieves a sub-linear convergence rate. We then apply our method to objective functions based on the (extended) persistent homology map computed over lower-star filters, which is a central tool of Topological Data Analysis. For this, we propose an efficient exploration of the corresponding stratification by using the Cayley graph of the permutation group. Finally, we provide benchmarks and novel topological optimization problems that demonstrate the utility and applicability of our framework.
main_arxiv.pdf (1.21 Mo) Télécharger le fichier
hal-03330940 , version 1 (01-09-2021)
hal-03330940 , version 2 (03-09-2021)
Paternité
Jacob Leygonie, Mathieu Carrière, Théo Lacombe, Steve Oudot. A Gradient Sampling Algorithm for Stratified Maps with Applications to Topological Data Analysis. Mathematical Programming, 2023, 202, pp.199-239. ⟨10.1007/s10107-023-01931-x⟩. ⟨hal-03330940v2⟩
112 Consultations
113 Téléchargements
