Discrete pseudo-differential operators and applications to numerical schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We define a class of discrete operators acting on infinite, finite or periodic sequences mimicking the standard properties of pseudo-differential operators. In particular we can define the notion of order and regularity, and we recover the fundamental property that the commutator of two discrete operators gains one order of regularity. We show that standard differential operators acting on periodic functions, finite difference operators and fully discrete pseudo-spectral methods fall into this class of discrete pseudo-differential operators. As examples of practical applications, we revisit standard error estimates for the convergence of splitting methods, obtaining in some Hamiltonian cases no loss of derivative in the error estimates, in particular for discretizations of general waves and/or water-waves equations. Moreover, we give an example of preconditioner constructions inspired by normal form analysis to deal with the similar question for more general cases.
DiscretePseudo.pdf (391.5 Ko) Télécharger le fichier
hal-03360120 , version 1 (30-09-2021)
Erwan Faou, Benoît Grébert. Discrete pseudo-differential operators and applications to numerical schemes. 2021. ⟨hal-03360120⟩
52 Consultations
159 Téléchargements
