New interface
Reports (Research report)
Visually-Uniform Reparametrization of Material Appearance through Density Redistribution
Pascal Barla 1 Laurent Belcour 2 Romain Pacanowski 1
1 MANAO - Melting the frontiers between Light, Shape and Matter
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, LP2N - Laboratoire Photonique, Numérique et Nanosciences
Abstract : Variations of material parameters such as roughness, sheen, etc. do not usually produce visually-uniform changes in rendered images. This might make it detrimental to artistic edition or prefiltering. In this work, we provide a methodology to reparametrize non visuallyuniform parameters, by uniformly distributing the visual changes across the range of parameter values. For 1D and 2D parameters, our solution boils down to inverting a Cumulative Distribution Function. We provide three concrete applications of this method to reparametrize the complex refractive index, roughness and sheen.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03367475
Contributor : Pascal Barla Connect in order to contact the contributor
Submitted on : Tuesday, October 12, 2021 - 11:17:03 AM
Last modification on : Friday, November 18, 2022 - 9:27:01 AM
File
RR-9424.pdf
Identifiers
  • HAL Id : hal-03367475, version 2
Collections
Citation
Pascal Barla, Laurent Belcour, Romain Pacanowski. Visually-Uniform Reparametrization of Material Appearance through Density Redistribution. [Research Report] RR-9424, Inria Bordeaux - Sud Ouest; Unity Technologies. 2021. ⟨hal-03367475v2⟩
Share
Metrics
Record views
86
Files downloads
109
