Loosely coupled, non-iterative time-splitting scheme based on Robin-Robin coupling: Unified analysis for Parabolic/Parabolic and Parabolic/Hyperbolic problems
We present a loosely coupled, non-iterative time-splitting scheme based on Robin-Robin coupling conditions. We apply a novel unified analysis for this scheme applied to both a Parabolic/Parabolic coupled system and a Parabolic/Hyperbolic coupled system. We show for both systems that the scheme is stable, and the error converges as O(∆(T + log(1/∆t))^1/2), where ∆t is the time step.
Origine | Fichiers produits par l'(les) auteur(s) |
