Polynomial surrogates for Bayesian traveltime tomography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue GEM - International Journal on Geomathematics Année : 2021
This paper tackles the issue of the computational load encountered in seismic imaging by Bayesian traveltime inversion. In Bayesian inference, the exploration of the posterior distribution of the velocity model parameters requires extensive sampling. The computational cost of this sampling step can be prohibitive when the first arrival traveltime prediction involves the resolution of an expensive number of forward models based on the eikonal equation. We propose to rely on polynomial chaos surrogates of the traveltimes between sources and receivers to alleviate the computational burden of solving the eikonal equation during the sampling stage. In an offline stage, the approach builds a functional approximation of the traveltimes from a set of solutions of the eikonal equation corresponding to a few values of the velocity model parameters selected in their prior range. These surrogates then substitute the eikonal-based predictions in the posterior evaluation, enabling very efficient extensive sampling of Bayesian posterior, for instance, by a Markov Chain Monte Carlo (MCMC) algorithm. We demonstrate the potential of the approach using numerical experiments on the inference of two-dimensional domains with layered velocity models and different acquisition geometries (microseismic and seismic refraction contexts). The results show that, in our experiments, the number of eikonal model evaluations required to construct accurate surrogates of the traveltimes is low. Further, an accurate and complete characterization of the posterior distribution of the velocity model is possible, thanks to the generation of large sample sets at a low cost. Finally, we discuss the extension of the current approach to more realistic velocity models and operational situations.
preprint.pdf (3.52 Mo) Télécharger le fichier
hal-03384145 , version 1 (18-10-2021)
Pierre Sochala, Alexandrine Gesret, Olivier Le Maitre. Polynomial surrogates for Bayesian traveltime tomography. GEM - International Journal on Geomathematics, 2021, 12 (1), ⟨10.1007/s13137-021-00184-0⟩. ⟨hal-03384145⟩
110 Consultations
99 Téléchargements
