Robust output feedback MPC of time-delayed systems using interval observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
This work addresses the problem of robust output feedback model predictive control (MPC) of constrained, discrete-time, time-delayed linear systems subject to (bounded) additive disturbances. The proposed predictive controller incorporates an interval observer, that exploits the available measurement to update the setmembership of the system states, and an interval predictor, used in the prediction step of the MPC. The proposed algorithm is similar to conventional MPC for linear systems, offering guarantees on recursive feasibility and robust constraint satisfaction, with low computational complexity. Furthermore, the delay is explicitly taken into account in the design, and the obtained scheme easily encompasses delays on the state, on the measurement or the control input.
_DelayMPC.pdf (480.13 Ko) Télécharger le fichier
hal-03385020 , version 1 (19-10-2021)
Denis Efimov, Alex Reis de Souza, Tarek Raïssi. Robust output feedback MPC of time-delayed systems using interval observers. International Journal of Robust and Nonlinear Control, inPress, ⟨10.1002/rnc.5874⟩. ⟨hal-03385020⟩
77 Consultations
297 Téléchargements
