Nearly Tight Convergence Bounds for Semi-discrete Entropic Optimal Transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We derive nearly tight and non-asymptotic convergence bounds for solutions of entropic semi-discrete optimal transport. These bounds quantify the stability of the dual solutions of the regularized problem (sometimes called Sinkhorn potentials) w.r.t. the regularization parameter, for which we ensure a better than Lipschitz dependence. Such facts may be a first step towards a mathematical justification of annealing or $\varepsilon$-scaling heuristics for the numerical resolution of regularized semi-discrete optimal transport. Our results also entail a non-asymptotic and tight expansion of the difference between the entropic and the unregularized costs.
bounds_entropic_sdot.pdf (608.3 Ko) Télécharger le fichier
hal-03396206 , version 1 (22-10-2021)
hal-03396206 , version 2 (29-11-2021)
  • HAL Id : hal-03396206 , version 1
Alex Delalande. Nearly Tight Convergence Bounds for Semi-discrete Entropic Optimal Transport. 2021. ⟨hal-03396206v1⟩
91 Consultations
44 Téléchargements
