Nearly Tight Convergence Bounds for Semi-discrete Entropic Optimal Transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We derive nearly tight and non-asymptotic convergence bounds for solutions of entropic semi-discrete optimal transport. These bounds quantify the stability of the dual solutions of the regularized problem (sometimes called Sinkhorn potentials) w.r.t. the regularization parameter, for which we ensure a better than Lipschitz dependence. Such facts may be a first step towards a mathematical justification of annealing or $\varepsilon$-scaling heuristics for the numerical resolution of regularized semi-discrete optimal transport. Our results also entail a non-asymptotic and tight expansion of the difference between the entropic and the unregularized costs.
main.pdf (608.76 Ko) Télécharger le fichier
hal-03396206 , version 1 (22-10-2021)
hal-03396206 , version 2 (29-11-2021)
  • HAL Id : hal-03396206 , version 2
Alex Delalande. Nearly Tight Convergence Bounds for Semi-discrete Entropic Optimal Transport. AISTATS 2022 - 25th International Conference on Artificial Intelligence and Statistics, Mar 2022, Valencia / Virtual, Spain. pp.1619-1642. ⟨hal-03396206v2⟩
91 Consultations
44 Téléchargements
