Switching controls for parabolic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Palestine Journal of Mathematics Année : 2023
We consider the controllability of an abstract parabolic system by using switching controls. More precisely, we show that under general hypotheses, if a parabolic system is null-controllable for any positive time with N controls, then it is also null-controllable with the property that at each time, only one of these controls is active. The main difference with previous results in the literature is that we can handle the case where the main operator of the system is not self-adjoint. We give several examples to illustrate our result: coupled heat equations with terms of orders 0 and 1, the Oseen system or the Boussinesq system.
BadraTakahashi-05-11-2021.pdf (372.94 Ko) Télécharger le fichier
hal-03417266 , version 1 (05-11-2021)
  • HAL Id : hal-03417266 , version 1
Mehdi Badra, Takéo Takahashi. Switching controls for parabolic systems. Palestine Journal of Mathematics, 2023. ⟨hal-03417266⟩
80 Consultations
88 Téléchargements
