First equilibrium reconstruction for ITER with the code NICE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Instrumentation Année : 2022
In this short paper we present the first application of the IMAS compatible code NICE to equilibrium reconstruction for ITER geometry. The inverse problem is formulated as a least square problem and the numerical methods implemented in NICE in order to solve it are presented. The results of a numerical experiment are shown: a reference equilibrium is computed from which a set of synthetic magnetic measurements are extracted. Then these measurements are used successfully to reconstruct the equilibrium of the plasma.
hal-03590775 , version 1 (10-11-2021)
hal-03590775 , version 2 (28-02-2022)
Blaise Faugeras, Jacques Blum, Cedric Boulbe. First equilibrium reconstruction for ITER with the code NICE. Journal of Instrumentation, 2022, 17 (02), pp.C02024. ⟨10.1088/1748-0221/17/02/c02024⟩. ⟨hal-03590775v2⟩
110 Consultations
0 Téléchargements
