Active vibration control of axisymmetric membrane through partial pole placement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the problem of active vibration control for a flexible axisymmetric membrane. This mechanical system is equipped with two piezoelectric circular chips where one of them works as an actuator, whereas the other is used as a sensor. Both are glued on the membrane, one on each side, and centered according to its axis of symmetry. The model of this system is obtained from a finite element modelling, leading to a linear state-space model. The design of the proposed controller is based on delayed proportional actions. We exploit a property called Coexisting Real Roots inducing Dominancy to an assignment of spectral values in an appropriate sector corresponding to a desired damping. The aim of this work is to examine the performances of the proposed output feedback controller in terms of vibration damping of the main observable and controllable vibrating modes.
TDS_2021_FTBN_Vibration_Damping-4.pdf (848.14 Ko) Télécharger le fichier
hal-03427577 , version 1 (14-11-2021)
Ricardo Falcón-Prado, Sami Tliba, Islam Boussaada, Silviu-Iulian Niculescu. Active vibration control of axisymmetric membrane through partial pole placement. TDS 2021 - 16th IFAC Workshop on Time Delay Systems, Sep 2021, Guangzhou, China. ⟨10.1016/j.ifacol.2021.11.116⟩. ⟨hal-03427577⟩
41 Consultations
51 Téléchargements
