SOME FACTORS OF NUMBERS OF THE FORM b^n ± 1 FOUND USING ECM WITH NEW CLASSES OF CURVES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this note, we list factors of numbers of the form b^n+/-1 found using GMP-ECM and new classes of elliptic curves.
factors.pdf (160.6 Ko) Télécharger le fichier
hal-03437714 , version 1 (20-11-2021)
hal-03437714 , version 2 (31-03-2022)
  • HAL Id : hal-03437714 , version 1
François Morain. SOME FACTORS OF NUMBERS OF THE FORM b^n ± 1 FOUND USING ECM WITH NEW CLASSES OF CURVES. 2021. ⟨hal-03437714v1⟩
172 Consultations
124 Téléchargements
