Observing a Unicycle Robot with Data Rate Constraints: a Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we consider the problem of remote observation of a unicycle-type mobile robot through a data rate constrained communication channel, which can only send a limited number of bits per unit of time. The objective is to reconstruct estimates of the state of the robot at the remote location through the messages that are sent. The design of the communication protocol should ensure that the maximum observation error is bounded whilst using as few bits per unit of time as possible. An event-triggered observation scheme is developed specifically for the unicycle-type robot. This observer is tested through experiments on Turtlebots. The experiments show that the event-triggered scheme is very efficient at reducing the average number of required communications.
CDC21_Quentin.pdf (1.26 Mo) Télécharger le fichier
hal-03439154 , version 1 (22-11-2021)
  • HAL Id : hal-03439154 , version 1
Quentin Voortman, Denis Efimov, Alexander Pogromsky, Haik Silm, Jean-Pierre Richard, et al.. Observing a Unicycle Robot with Data Rate Constraints: a Case Study. Proc. 60th IEEE Conference on Decision and Control (CDC), Dec 2021, Austin, United States. ⟨hal-03439154⟩
39 Consultations
84 Téléchargements
