Receiver-Device-Independent Quantum Key Distribution Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We consider a receiver-device-independent (RDI) approach to quantum key distribution. Specifically, we discuss protocols for a prepare-and-measure scenario and present a detailed security analysis. The sender's (Alice's) device is partially characterized, in the sense that we assume bounds on the overlaps of the prepared quantum states. The receiver's (Bob's) device requires no characterisation and can be represented as a black-box. Our protocols are therefore robust to any attack onBob, such as blinding attacks. In particular, we show that a secret key can be established even when the quantum channel has arbitrarily low transmission by considering RDI protocols exploiting sufficiently many states. Finally, we discuss how the hypothesis of bounded overlaps can be naturally applied to practical devices.
Mots clés
2111.04351.pdf (760.45 Ko) Télécharger le fichier
hal-03441473 , version 1 (15-12-2021)
hal-03441473 , version 2 (17-06-2022)
Marie Ioannou, Pavel Sekatski, Alastair A. Abbott, Denis Rosset, Jean-Daniel Bancal, et al.. Receiver-Device-Independent Quantum Key Distribution Protocols. 2021. ⟨hal-03441473v1⟩
117 Consultations
41 Téléchargements
