Receiver-device-independent quantum key distribution protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue New Journal of Physics Année : 2022
We discuss quantum key distribution protocols and their security analysis, considering a receiver-device-independent (RDI) model. The sender’s (Alice’s) device is partially characterized, in the sense that we assume bounds on the overlaps of the prepared quantum states. The receiver’s (Bob’s) device requires no characterisation and can be represented as a black-box. Our protocols are therefore robust to any attack on Bob, such as blinding attacks. In particular, we show that a secret key can be established even when the quantum channel has arbitrarily low transmission by considering RDI protocols exploiting sufficiently many states. Finally, we discuss how the hypothesis of bounded overlaps can be naturally applied to practical devices.
Ioannou_2022_New_J._Phys._24_063006.pdf (1.89 Mo) Télécharger le fichier
hal-03441473 , version 1 (15-12-2021)
hal-03441473 , version 2 (17-06-2022)
Marie Ioannou, Pavel Sekatski, Alastair A. Abbott, Denis Rosset, Jean-Daniel Bancal, et al.. Receiver-device-independent quantum key distribution protocols. New Journal of Physics, 2022, 24 (6), pp.063006. ⟨10.1088/1367-2630/ac71bc⟩. ⟨hal-03441473v2⟩
116 Consultations
41 Téléchargements
