Extended Path Filter Configurations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stefano Tamiazzo
  • Fonction : Auteur
  • PersonId : 1118080
In this work we introduce a method for increasing the maximum number of transmission zeros in the response of path filters. This recently introduced inline filter configuration allows for up to four transmission zeros on the imaginary axis. The solution proposed in this work, while maintaining the inline configuration, increases the number of transmission zeros up to N-1 (with N order of the filter). The novel concept allowing the additional zeros introduction is verified by means of the design of a waveguide filter of order 8 with 6 transmission zeros.
PaperFinal.pdf (411.09 Ko) Télécharger le fichier
hal-03448737 , version 1 (25-11-2021)
Stefano Tamiazzo, Giuseppe Macchiarella, Fabien Seyfert. Extended Path Filter Configurations. IMFW 2021 - International Microwave Filter Workshop, Nov 2021, Perugia, France. ⟨10.1109/IMFW49589.2021.9642343⟩. ⟨hal-03448737⟩
20 Consultations
99 Téléchargements
