TSO-DSOs Stable Cost Allocation for the Joint Procurement of Flexibility: A Cooperative Game Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this paper, a transmission-distribution systems flexibility market is introduced, in which system operators (SOs) jointly procure flexibility from different systems to meet their needs (balancing and congestion management) using a common market. This common market is, then, formulated as a cooperative game aiming at identifying a stable and efficient split of costs of the jointly procured flexibility among the participating SOs to incentivize their cooperation. The non-emptiness of the core of this game is then mathematically proven, implying the stability of the game and the naturally-arising incentive for cooperation among the SOs. Several cost allocation mechanisms are then introduced, while characterizing their mathematical properties. Numerical results focusing on an interconnected system (composed of the IEEE 14-bus transmission system and the Matpower 18-bus, 69-bus, and 141-bus distributions systems) showcase the cooperation-induced reduction in systemwide flexibility procurement costs, and identifies the varying costs borne by different SOs under various cost allocations methods.
Coordinet_Cooperative_game (1).pdf (465.89 Ko) Télécharger le fichier
hal-03449923 , version 1 (25-11-2021)
hal-03449923 , version 2 (18-02-2022)
hal-03449923 , version 3 (08-04-2022)
  • HAL Id : hal-03449923 , version 1
Anibal Sanjab, Hélène Le Cadre, Yuting Mou. TSO-DSOs Stable Cost Allocation for the Joint Procurement of Flexibility: A Cooperative Game Approach. 2021. ⟨hal-03449923v1⟩
192 Consultations
155 Téléchargements
