TSO-DSOs Stable Cost Allocation for the Joint Procurement of Flexibility: A Cooperative Game Approach
In this paper, a transmission-distribution systems flexibility market is introduced, in which system operators (SOs)
jointly procure flexibility from different systems to meet their needs (balancing and congestion management) using a common
market. This common market is, then, formulated as a cooperative game aiming at identifying a stable and efficient split of
costs of the jointly procured flexibility among the participating SOs to incentivize their cooperation. The non-emptiness of the
core of this game is then mathematically proven, implying the stability of the game and the naturally-arising incentive for
cooperation among the SOs. Several cost allocation mechanisms are then introduced, while characterizing their mathematical
properties. Numerical results focusing on an interconnected system (composed of the IEEE 14-bus transmission system
and the Matpower 18-bus, 69-bus, and 141-bus distributions systems) showcase the cooperation-induced reduction in systemwide
flexibility procurement costs, and identifies the varying costs borne by different SOs under various cost allocations methods.
