A High-Order Sliding-Mode Adaptive Observer for Uncertain Nonlinear Systems
A high-order sliding-mode adaptive observer is proposed to solve the problem of adaptive estimation, i.e., the simultaneous estimation of the state and parameters, for a class of uncertain nonlinear systems in the presence of external disturbances, that does not need to satisfy a relative degree condition equal to one. This approach is based on a highorder sliding-mode observer and a nonlinear parameter identification algorithm. The practical, global and uniform asymptotic stability of the adaptive estimation error, despite the external disturbances, is guaranteed through the small-gain theorem. The convergence proofs are developed based on Lyapunov and inputto-state stability theories. Some simulation results illustrate the performance of the proposed high-order sliding-mode adaptive observer.
Automatique / Robotique
