h and r adaptation on simplicial meshes using MMG tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We review some recent work on the enhancement and application of both − and ℎ− adaptation techniques, benefitting of the functionalities of the remeshing platform Mmg: www.mmgtools.org. Several contributions revolve around the level-set adaptation capabilities of the platform. These have been used to identify complex surfaces and then to either produce conformal 3D meshes, or to define a metric allowing to perform ℎ-adaptation and control geometrical errors in the context of immersed boundary flow simulations. The performance of the recent distributed memory parallel implementation ParMmg is also discussed. In a similar spirit, we propose some improvements of −adaptation methods to handle embedded fronts.
2109.08451.pdf (20.67 Mo) Télécharger le fichier
hal-03508493 , version 1 (03-01-2022)
Luca Arpaia, Heloise Beaugendre, Luca Cirrottola, Algiane Froehly, Marco Lorini, et al.. h and r adaptation on simplicial meshes using MMG tools. 2021. ⟨hal-03508493⟩
63 Consultations
61 Téléchargements
