Combining Dantzig-Wolfe and Benders decompositions to solve a large-scale nuclear outage planning problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Operational Research Année : 2022
Optimizing nuclear unit outages is of significant economic importance for the French electricity company EDF, as these outages induce a substitute production by other more expensive means to fulfill electricity demand. This problem is quite challenging given the specific operating constraints of nuclear units, the stochasticity of both the demand and non-nuclear units availability, and the scale of the instances. To tackle these difficulties we use a combined decomposition approach. The operating constraints of the nuclear units are built into a Dantzig-Wolfe pricing subproblem whose solutions define the columns of a demand covering formulation. The scenarios of demand and non-nuclear units availability are handled in a Benders decomposition. Our approach is shown to scale up to the real-life instances of the French nuclear fleet.
articleEJOR_final.pdf (824.98 Ko) Télécharger le fichier
hal-03521369 , version 1 (11-01-2022)
Rodolphe Griset, Pascale Bendotti, Boris Detienne, Marc Porcheron, Halil Şen, et al.. Combining Dantzig-Wolfe and Benders decompositions to solve a large-scale nuclear outage planning problem. European Journal of Operational Research, In press, 298 (3), pp.1067-1083. ⟨10.1016/j.ejor.2021.07.018⟩. ⟨hal-03521369⟩
51 Consultations
272 Téléchargements
