The Role of Dynamical Synapses in Retinal Surprise Coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
• Stimulation of a dissected retina with a sequence of periodic dark flashes. • Extracellular spike recordings. 2. Identification of necessary components via pharmacological inhibition of synaptic transmission onto : • ON bipolar cells via mGluR6 receptor antagonist LAP-4. • OFF bipolar cells via AMPA receptor antagonist ACET. Results ON BC inhibition cancels the OSR.
MOMI_Poster_SimoneEbert.pdf (1.3 Mo) Télécharger le fichier
hal-03521415 , version 1 (17-06-2022)
  • HAL Id : hal-03521415 , version 1
Simone Ebert, Semichan Sermet, Thomas Buffet, Olivier Marre, Bruno Cessac. The Role of Dynamical Synapses in Retinal Surprise Coding. MOMI2021: Le Monde des Mathematiques Industrielles, Mar 2021, Virtual, France. ⟨hal-03521415⟩
34 Consultations
10 Téléchargements
