Reinforcement learning with function approximation for 3-spheres swimmer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We study the swimming strategies that maximize the speed of the three-sphere swimmer using reinforcement learning methods. First of all, we ensure that for a simple model with few actions, the Q-learning method converges. However, this latter method does not fit a more complex framework (for instance the presence of boundary) where states or actions have to be continuous to obtain all directions in the swimmer's reachable set. To overcome this issue, we investigate another method from reinforcement learning which uses function approximation, and benchmark its results in absence of walls.
Article_IFAC_CAO_2021-4.pdf (409.42 Ko) Télécharger le fichier
hal-03538754 , version 1 (21-01-2022)
  • HAL Id : hal-03538754 , version 1
Luca Berti, Zakarya El Khiyati, Youssef Essousy, Christophe Prud'Homme, Laetitia Giraldi. Reinforcement learning with function approximation for 3-spheres swimmer. 2022. ⟨hal-03538754⟩
143 Consultations
114 Téléchargements
