Numerical analysis of a mixed-dimensional poromechanical model with frictionless contact at matrix–fracture interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2024
We present a complete numerical analysis for a general discretization of a coupled flowmechanics model in fractured porous media, considering single-phase flows and including frictionless contact at matrix-fracture interfaces, as well as nonlinear poromechanical coupling. Fractures are described as planar surfaces, yielding the so-called mixed-or hybrid-dimensional models. Small displacements and a linear elastic behavior are considered for the matrix. The model accounts for discontinuous fluid pressures at matrix-fracture interfaces in order to cover a wide range of normal fracture conductivities. The numerical analysis is carried out in the Gradient Discretization framework, encompassing a large family of conforming and nonconforming discretizations. The convergence result also yields, as a by-product, the existence of a weak solution to the continuous model. A numerical experiment in 2D is presented to support the obtained result, employing a Hybrid Finite Volume scheme for the flow and second-order finite elements ($\mathbb P_2$) for the mechanical displacement coupled with face-wise constant ($\mathbb P_0$) Lagrange multipliers on fractures, representing normal stresses, to discretize the contact conditions.
Convergence-poromeca-contact-v3.pdf (1.22 Mo) Télécharger le fichier
hal-03541096 , version 1 (24-01-2022)
hal-03541096 , version 2 (23-01-2024)
Francesco Bonaldi, Jérôme Droniou, Roland Masson. Numerical analysis of a mixed-dimensional poromechanical model with frictionless contact at matrix–fracture interfaces. Mathematics of Computation, In press, ⟨10.1090/mcom/3949⟩. ⟨hal-03541096v2⟩
150 Consultations
100 Téléchargements
