Neural Precomputed Radiance Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2022
Recent advances in neural rendering indicate immense promise for architectures that learn light transport, allowing efficient rendering of global illumination effects once such methods are trained. The training phase of these methods can be seen as a form of pre-computation, which has a long standing history in Computer Graphics. In particular, Pre-computed Radiance Transfer (PRT) achieves real-time rendering by freezing some variables of the scene (geometry, materials) and encoding the distribution of others, allowing interactive rendering at runtime. We adopt the same configuration as PRT – global illumination of static scenes under dynamic environment lighting – and investigate different neural network architectures, inspired by the design principles and theoretical analysis of PRT. We introduce four different architectures, and show that those based on knowledge of light transport models and PRT-inspired principles improve the quality of global illumination predictions at equal training time and network size, without the need for high-end ray-tracing hardware.
nprt.pdf (49.1 Mo) Télécharger le fichier
hal-03581439 , version 1 (19-02-2022)
Gilles Rainer, Adrien Bousseau, Tobias Ritschel, George Drettakis. Neural Precomputed Radiance Transfer. Computer Graphics Forum, In press, ⟨10.1111/cgf.14480⟩. ⟨hal-03581439⟩
138 Consultations
48 Téléchargements
