A variational approach for joint image recovery-segmentation based on spatially varying generalised Gaussian models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The joint problem of reconstruction/feature extraction is a challenging task in image processing. It consists in performing, in a joint manner, the restoration of an image and the extraction of its features. In this work, we firstly propose a novel nonsmooth and nonconvex variational formulation of the problem. For this purpose, we introduce a versatile generalised Gaussian prior whose parameters, including its exponents, are space-variant. Secondly, we design an alternating proximal-based optimisation algorithm that efficiently exploits the structure of the proposed nonconvex objective function. We also analyze the convergence of this algorithm. As shown in numerical experiments conducted on joint segmentation/deblurring tasks, the proposed method provides high-quality results.
Chouzeoux Corbineau Pesquet Scrivanti - Variational approach for joint image reconvery-segmentation.pdf (1.22 Mo) Télécharger le fichier
hal-03591742 , version 1 (28-02-2022)
hal-03591742 , version 2 (11-10-2023)
hal-03591742 , version 3 (18-03-2024)
  • HAL Id : hal-03591742 , version 1
Emilie Chouzenoux, Marie-Caroline Corbineau, Jean-Christophe Pesquet, Gabriele Scrivanti. A variational approach for joint image recovery-segmentation based on spatially varying generalised Gaussian models. 2022. ⟨hal-03591742v1⟩
Collections
GS-ENGINEERING
133 Consultations
234 Téléchargements
