A variational approach for joint image recovery and feature extraction based on spatially varying generalised Gaussian models
The joint problem of reconstruction / feature extraction is a challenging task in image processing. It
consists in performing, in a joint manner, the restoration of an image and the extraction of its features.
In this work, we firstly propose a novel nonsmooth and non-convex variational formulation of
the problem. For this purpose, we introduce a versatile generalised Gaussian prior whose parameters,
including its exponent, are space-variant. Secondly, we design an alternating proximal-based optimisation
algorithm that efficiently exploits the structure of the proposed non-convex objective function.
We also analyse the convergence of this algorithm. As shown in numerical experiments conducted on
joint deblurring/segmentation tasks, the proposed method provides high-quality results.
