And Rijndael? Automatic Related-key Differential Analysis of Rijndael - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Finding optimal related-key differential characteristics for a given cipher is a problem that hardly scales. For the first time, we study this problem against the 25 instances of the block cipher Rijndael, which are the little brothers of the AES. To achieve this, we adapt and improve an existing approach for the AES which is based on Constraint Programming. The attacks presented here overpass all the previous cryptanalytic results of Rijndael. Among all our results, we obtain a 12-round (out of 13 rounds) related-key differential attack for Rijndael with a block size equal to 128 bits and a key size equal to 224 bits. We also obtain an 11-round related-key differential characteristic distinguisher for Rijndael with a block size equal to 160 bits and a key size equal to 256 bits leading to an attack on 12 rounds (out of 14 rounds).
africacrypt22.pdf (551.28 Ko) Télécharger le fichier
hal-03671013 , version 1 (18-05-2022)
Paternité
Loïc Rouquette, David Gerault, Marine Minier, Christine Solnon. And Rijndael? Automatic Related-key Differential Analysis of Rijndael. AfricaCrypt 2022 - 13th International Conference on Cryptology in Africa, Jul 2022, Fes, Morocco. pp.150-175, ⟨10.1007/978-3-031-17433-9_7⟩. ⟨hal-03671013⟩
259 Consultations
312 Téléchargements
