How environment affects active particle swarms: a case study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Royal Society Open Science Année : 2022
We investigate the collective motion of self-propelled agents in an environment filled with obstacles that are tethered to fixed positions via springs. The active particles are able to modify the environment by moving the obstacles through repulsion forces. This creates feedback interactions between the particles and the obstacles from which a breadth of patterns emerges (trails, band, clusters, honeycomb structures,...). We will focus on a discrete model first introduced in [Aceves2020] and derived into a continuum PDE model. As a first major novelty, we perform an in-depth investigation of pattern formation of the discrete and continuum models in 2D: we provide phase-diagrams and determine the key mechanisms for bifurcations to happen using linear stability analysis. As a result, we discover that the agent-agent repulsion, the agent-obstacle repulsion and the obstacle's spring stiffness are the key forces in the appearance of patterns, while alignment forces between the particles play a secondary role. The second major novelty lies in the development of an innovative methodology to compare discrete and continuum models that we apply here to perform an in-depth analysis of the agreement between the discrete and continuum models.
Swimmers-ARXIV.pdf (4.78 Mo) Télécharger le fichier
hal-03684115 , version 1 (01-06-2022)
  • HAL Id : hal-03684115 , version 1
Pierre Degond, Angelika Manhart, Sara Merino-Aceituno, Diane Peurichard, Lorenzo Sala. How environment affects active particle swarms: a case study. Royal Society Open Science, 2022, 9, pp.220791. ⟨hal-03684115⟩
86 Consultations
27 Téléchargements
