Stability and String Stability of Car-following Models with Reaction-time Delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We investigate the transfer function emanating from the linearization of a car-following model, when taking into account a driver reaction time. This leads to stability conditions, which are explicitly given. We also show how this reaction time can introduce a weak string instability. This is a preliminary step of a forthcoming work about traffic stabilization via connected automated vehicles.
Transfer_function-draft.pdf (734.4 Ko) Télécharger le fichier
hal-03697661 , version 3 (06-04-2020)
hal-03697661 , version 6 (28-04-2020)
hal-03697661 , version 7 (30-04-2020)
hal-03697661 , version 8 (04-12-2020)
hal-03697661 , version 9 (17-06-2022)
  • HAL Id : hal-03697661 , version 6
Guy Fayolle, Jean-Marc Lasgouttes, Carlos Flores. Stability and String Stability of Car-following Models with Reaction-time Delay. 2020. ⟨hal-03697661v6⟩
420 Consultations
697 Téléchargements
