Stability and String Stability of Car-following Models with Reaction-time Delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We investigate the transfer function emanating from the linearization of a car-following model, when taking into account a driver reaction time. This leads to nontrivial stability conditions, which are explicitly given. They are in particular satisfied whenever string stability holds. We also show how this reaction time can introduce a partial string stability, where the transfer function modulus remains smaller or equal to 1 up to some critical frequency. We explore conditions in the parameter space discriminating between the different regimes. This is a preliminary step of a forthcoming work about traffic stabilization via connected automated vehicles.
Transfer_function.pdf (460.31 Ko) Télécharger le fichier
hal-03697661 , version 3 (06-04-2020)
hal-03697661 , version 6 (28-04-2020)
hal-03697661 , version 7 (30-04-2020)
hal-03697661 , version 8 (04-12-2020)
hal-03697661 , version 9 (17-06-2022)
  • HAL Id : hal-03697661 , version 7
Guy Fayolle, Jean-Marc Lasgouttes, Carlos Flores. Stability and String Stability of Car-following Models with Reaction-time Delay. 2020. ⟨hal-03697661v7⟩
420 Consultations
700 Téléchargements
