Boundary stabilization of one-dimensional cross-diffusion systems in a moving domain: linearized system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2023
We study the boundary stabilization of one-dimensional cross-diffusion systems in a moving domain. We show first exponential stabilization and then finite-time stabilization in arbitrary small time of the linearized system around uniform equilibria, provided the system has an entropic structure with a symmetric mobility matrix. One example of such systems are the equations describing a Physical Vapor Deposition (PVD) process. This stabilization is achieved with respect to both the volumic fractions and the thickness of the domain. The feedback control is derived using the backstepping technique, adapted to the context of a time-dependent domain. In particular, the norm of the backward backstepping transform is carefully estimated with respect to time.
Boundary_stabilization_of_a_1D_cross_diffusion_system__linear.pdf (696.18 Ko) Télécharger le fichier
hal-03706841 , version 1 (28-06-2022)
hal-03706841 , version 2 (13-01-2023)
Jean Cauvin-Vila, Virginie Ehrlacher, Amaury Hayat. Boundary stabilization of one-dimensional cross-diffusion systems in a moving domain: linearized system. Journal of Differential Equations, 2023, 350, pp.251-307. ⟨10.1016/j.jde.2022.12.021⟩. ⟨hal-03706841v2⟩
149 Consultations
119 Téléchargements
