Dynamical Synapses in Retinal Surprise coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
• Stimulation a dissected retina with a sequence of periodic dark flashes • Extracellular spike recordings. 2. Identification of necessary components via pharmacological inhibition of synaptic transmission onto : • ON bipolar cells via mGluR6 receptor antagonist LAP-4. • OFF bipolar cells via AMPA receptor antagonist ACET. Results ON BC inhibition cancels the OSR.
presentation_ICMNS_Simone__Ebert.pdf (241.89 Ko) Télécharger le fichier
hal-03716437 , version 1 (07-07-2022)
  • HAL Id : hal-03716437 , version 1
Thomas Buffet, Semihchan Sermet, Olivier Marre, Bruno Cessac, Simone Bertoli. Dynamical Synapses in Retinal Surprise coding. ICMNS 2022 - 2022 International Conference on Mathematical Neuroscience, Jul 2022, online, France. . ⟨hal-03716437⟩
76 Consultations
28 Téléchargements
