From Vlasov equation to degenerate nonlocal Cahn-Hilliard equation
We provide a rigorous mathematical framework to establish the hydrodynamic limit of the Vlasov model introduced by Noguchi and Takata in order to describe phase transition of fluids by kinetic equations. We prove that, when the scale parameter tends to 0, this model converges to a nonlocal Cahn-Hilliard equation with degenerate mobility. For our analysis, we introduce apropriate forms of the short and long range potentials which allow us to derive Helmhotlz free energy estimates. Several compactness properties follow from the energy, the energy dissipation and kinetic averaging lemmas. In particular we prove a new weak compactness bound on the flux.
