Multi-objective optimization of layout with functional constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimization and Engineering Année : 2022
The conventional layout problem is concerned with finding the arrangements of components inside the container to optimize objectives under geometrical constraints, i.e., no component overlap and no container protrusion. In this paper, the multi-objective optimization for layout balance and component activity requirements with functional constraints is developed. Integrating the accessibility of components as functional constraints ensures components maintenance or proper operation. However, addressing the functional constraints increase the complexity of the layout optimization. A novel multi-objective optimization algorithm is proposed using the constructive placement and the simulated annealing to search for compromised solutions between the two objectives. Thereafter, a similarity indicator is defined to evaluate how similar optimized layout designs are. The experiments indicate that the proposed optimization approach performs well in ensuring accessibility and efficiently finding high-qualified solutions, where the constructive placement largely contributes to the search for alternatives satisfying constraints.
OPTE_final.pdf (9.15 Mo) Télécharger le fichier
hal-03749692 , version 1 (11-08-2022)
Xiaoxiao Song, Emilie Poirson, Yannick Ravaut, Fouad Bennis. Multi-objective optimization of layout with functional constraints. Optimization and Engineering, inPress, ⟨10.1007/s11081-022-09754-z⟩. ⟨hal-03749692⟩
105 Consultations
31 Téléchargements
