Accelerated convergence with improved robustness for discrete-time parameter estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2022
The dynamic regressor extension and mixing (DREM) method provides a fixedtime converging parameter estimator for persistently excited regressor under bounded measurement noises. This note aims to develop this approach for cases with weaker excitation and regressor constraints. Several nonlinear estimation schemes with fixed-time convergence rates and improved measurement noise robustness properties are proposed here.
Accelerated_convergence_SCL_R0.pdf (561.92 Ko) Télécharger le fichier
hal-03760746 , version 1 (25-08-2022)
Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov, Jian Wang. Accelerated convergence with improved robustness for discrete-time parameter estimation. Systems and Control Letters, 2022, 55 (12), pp.324-329. ⟨10.1016/j.sysconle.2022.105344⟩. ⟨hal-03760746⟩
144 Consultations
99 Téléchargements
