Duality analysis of interior penalty discontinuous Galerkin methods under minimal regularity and application to the a priori and a posteriori error analysis of Helmholtz problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
We consider interior penalty discontinuous Galerkin discretizations of timeharmonic wave propagation problems modeled by the Helmholtz equation, and derive novel a priori and a posteriori estimates. Our analysis classically relies on duality arguments of Aubin-Nitsche type, and its originality is that it applies under minimal regularity assumptions. The estimates we obtain directly generalize known results for conforming discretizations, namely that the discrete solution is optimal in a suitable energy norm and that the error can be explicitly controlled by a posteriori estimators, provided the mesh is sufficiently fine.
chaumontfrelet_2022b.pdf (411.47 Ko) Télécharger le fichier
hal-03765207 , version 1 (31-08-2022)
hal-03765207 , version 2 (20-01-2024)
Paternité
Théophile Chaumont-Frelet. Duality analysis of interior penalty discontinuous Galerkin methods under minimal regularity and application to the a priori and a posteriori error analysis of Helmholtz problems. 2024. ⟨hal-03765207v2⟩
56 Consultations
41 Téléchargements
