YALTAPy and YALTAPy_Online: Python toolboxes for the H∞-stability analysis of classical and fractional systems with commensurate delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this paper is to give a presentation of the Python toolbox YALTAPy dedicated to the stability study of standard and fractional delay systems as well as its online version YALTAPy_Online. Both toolboxes are derived from YALTA whose functionalities will be recalled here. Examples will be given to show how these toolboxes may be used.
yalta.pdf (443.89 Ko) Télécharger le fichier
hal-03774603 , version 1 (11-09-2022)
Hugo Cavalera, Jayvir Raj, Guilherme Mazanti, Catherine Bonnet. YALTAPy and YALTAPy_Online: Python toolboxes for the H∞-stability analysis of classical and fractional systems with commensurate delays. TDC 2022 - 17th IFAC Workshop on Time Delay Systems, Sep 2022, Montréal, Canada. pp.192--197, ⟨10.1016/j.ifacol.2022.11.356⟩. ⟨hal-03774603⟩
58 Consultations
40 Téléchargements
