Characterization of the dynamic behavior of a diving board using motion capture data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sports Engineering Année : 2022
The interaction between a diver and a diving board is one of the key factors of springboard diving performance. An accurate modelling of this interaction could provide new tools to better understand springboard diving performance. This study presents a finite element model of a springboard driven by motion capture data. The aim was to identify springboard mechanical parameters allowing to obtain a model with a mechanical behaviour similar to that observed experimentally. The mechanical characterization method was based on motion capture data of the diver and the springboard. Firstly, these data were used to estimate the interaction forces and moments between the diver and the springboard using an optimization approach. The interaction forces and moments were then applied to the springboard model to be characterized. Finally, the model parameters were identified minimizing the discrepancy between the experimental and numerical vertical displacements of the springboard. The best model obtained from this method led to a maximal mean absolute error between the experimental and numerical vertical displacements between 0.045 m and 0.060 m. An accurate model may help to better understand energy transfers and time synchronisation between the diver and the springboard, which are key points of the diving board performance.
Characterization_Springer___Final_Version.pdf (1.34 Mo) Télécharger le fichier
hal-03788858 , version 1 (27-09-2022)
  • HAL Id : hal-03788858 , version 1
Louise Demestre, Stéphane Grange, Cécile Dubois, Nicolas Bideau, Guillaume Nicolas, et al.. Characterization of the dynamic behavior of a diving board using motion capture data. Sports Engineering, 2022, pp.1-18. ⟨hal-03788858⟩
127 Consultations
303 Téléchargements
