Conditions for uniform ensemble output controllability, and obstruction to uniform ensemble controllability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Control and Related Fields Année : 2024
We consider the linear time-invariant system ẋ(t, θ) = A(θ)x(t, θ) + B(θ)u(t) with output y(t, θ) = C(θ)x(t, θ) where A, B and C are continuous matrices with respect to the constant parameter θ, which belongs to some compact set P. Given any continuous initial state datum θ → x₀(θ) and any continuous output function θ → y₁(θ), we investigate the existence of a θ-independent open loop control u such that x₀ is steered, in nite time, arbitrarily closed to y₁ with the uniform norm. When C(θ) is the identity matrix, this notion is usually termed to be uniform ensemble controllability. In this paper, we extend some result on uniform ensemble controllability to the case where C(θ) is not the identity matrix. We will also give some obstructions to ensemble controllability when the parameter set admits an interior point.
UEOC.pdf (2.33 Mo) Télécharger le fichier
hal-03824645 , version 1 (21-10-2022)
hal-03824645 , version 2 (09-10-2023)
Baparou Danhane, Jérôme Lohéac, Marc Jungers. Conditions for uniform ensemble output controllability, and obstruction to uniform ensemble controllability. Mathematical Control and Related Fields, In press, ⟨10.3934/mcrf.2023036⟩. ⟨hal-03824645v2⟩
180 Consultations
117 Téléchargements
