Complete Positivity Violation in Higher-order Quantum Adiabatic Elimination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
When a composite Lindblad system consists of weakly coupled sub-systems with fast and slow timescales, the description of slow dynamics can be simplified by discarding fast degrees of freedom. This model reduction technique is called adiabatic elimination. While second-order perturbative expansion with respect to the timescale separation has revealed that the evolution of a reduced state is completely positive, this paper presents an example exhibiting complete positivity violation in the fourth-order expansion. Despite the non-uniqueness of slow dynamics parametrization, we prove that complete positivity cannot be ensured in any parametrization. The violation stems from correlation in the initial state.
2211.11008.pdf (142.94 Ko) Télécharger le fichier
hal-03868312 , version 1 (17-01-2023)
Masaaki Tokieda, Cyril Elouard, Alain Sarlette, Pierre Rouchon. Complete Positivity Violation in Higher-order Quantum Adiabatic Elimination. 2022. ⟨hal-03868312⟩
77 Consultations
38 Téléchargements
