Homogenization of some periodic Hamilton-Jacobi equations with defects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Partial Differential Equations Année : 2023
We study homogenization for a class of stationnary Hamilton-Jacobi equations in which the Hamiltonian is obtained by perturbing near the origin an otherwise periodic Hamiltonian. We prove that the limiting problem consists of a Hamilton-Jacobi equation outside the origin, with the same effective Hamiltonian as in periodic homogenization, supplemented at the origin with an effective Dirichlet condition that keeps track of the perturbation. Various comments and extensions are discussed.
YA_CLB_v3.pdf (461.67 Ko) Télécharger le fichier
hal-03870614 , version 1 (24-11-2022)
Yves Achdou, Claude Le Bris. Homogenization of some periodic Hamilton-Jacobi equations with defects. Communications in Partial Differential Equations, 2023, 48 (6), ⟨10.1080/03605302.2023.2238953⟩. ⟨hal-03870614⟩
47 Consultations
88 Téléchargements
