On the convergence of policy gradient methods to Nash equilibria in general stochastic games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Learning in stochastic games is a notoriously difficult problem because, in addition to each other's strategic decisions, the players must also contend with the fact that the game itself evolves over time, possibly in a very complicated manner. Because of this, the convergence properties of popular learning algorithms - like policy gradient and its variants - are poorly understood, except in specific classes of games (such as potential or two-player, zero-sum games). In view of this, we examine the long-run behavior of policy gradient methods with respect to Nash equilibrium policies that are second-order stationary (SOS) in a sense similar to the type of sufficiency conditions used in optimization. Our first result is that SOS policies are locally attracting with high probability, and we show that policy gradient trajectories with gradient estimates provided by the REINFORCE algorithm achieve an $\mathcal{O}(1/\sqrt{n})$ distance-squared convergence rate if the method's step-size is chosen appropriately. Subsequently, specializing to the class of deterministic Nash policies, we show that this rate can be improved dramatically and, in fact, policy gradient methods converge within a finite number of iterations in that case.
PolicyLearning-NIPS.pdf (792.22 Ko) Télécharger le fichier
hal-03874018 , version 1 (27-11-2022)
Angeliki Giannou, Kyriakos Lotidis, Panayotis Mertikopoulos, Emmanouil-Vasileios Vlatakis-Gkaragkounis. On the convergence of policy gradient methods to Nash equilibria in general stochastic games. NeurIPS 2022 - 36th International Conference on Neural Information Processing Systems, Nov 2022, New Orleans, United States. pp.1-43. ⟨hal-03874018⟩
62 Consultations
47 Téléchargements
