UnderGrad: A universal black-box optimization method with almost dimension-free convergence rate guarantees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Universal methods for optimization are designed to achieve theoretically optimal convergence rates without any prior knowledge of the problem's regularity parameters or the accurarcy of the gradient oracle employed by the optimizer. In this regard, existing state-of-the-art algorithms achieve an $\mathcal{O}(1/T^2)$ value convergence rate in Lipschitz smooth problems with a perfect gradient oracle, and an $\mathcal{O}(1/\sqrt{T})$ convergence rate when the underlying problem is non-smooth and/or the gradient oracle is stochastic. On the downside, these methods do not take into account the problem's dimensionality, and this can have a catastrophic impact on the achieved convergence rate, in both theory and practice. Our paper aims to bridge this gap by providing a scalable universal gradient method - dubbed UnderGrad - whose oracle complexity is almost dimension-free in problems with a favorable geometry (like the simplex, linearly constrained semidefinite programs and combinatorial bandits), while retaining the order-optimal dependence on $T$ described above. These "best-of-both-worlds" results are achieved via a primal-dual update scheme inspired by the dual exploration method for variational inequalities.
UnderGrad-ICML.pdf (2.01 Mo) Télécharger le fichier
hal-03874041 , version 1 (27-11-2022)
Kimon Antonakopoulos, Dong Quan Vu, Vokan Cevher, Kfir Yehuda Levy, Panayotis Mertikopoulos. UnderGrad: A universal black-box optimization method with almost dimension-free convergence rate guarantees. ICML 2022 - 39th International Conference on Machine Learning, Jul 2022, Baltimore, United States. pp.1-31. ⟨hal-03874041⟩
50 Consultations
15 Téléchargements
