Using the FES framework to derive new physical degrees of freedom for finite element spaces of differential forms
In this paper we study a geometric approach for constructing physical degrees of freedom for sequences of finite element spaces. Within the framework of finite element systems, we propose new degrees of freedom for the spaces PrΛ k of polynomial differential forms and we verify numerically their unisolvence.
Analyse numérique [math.NA]
