Analysis of a one dimensional energy dissipating free boundary model with nonlinear boundary conditions. Existence of global weak solutions
This work is part of a general study on the long-term safety of the geological repository of nuclear wastes. A diffusion equation with a moving boundary in one dimension is introduced and studied. The model describes some mechanisms involved in corrosion processes at the surface of carbon steel canisters in contact with a claystone formation. The main objective of the paper is to prove the existence of global weak solutions to the problem. For this, a semi-discrete in time minimizing movements scheme à la De Giorgi is introduced. First, the existence of solutions to the scheme is established and then, using a priori estimates, it is proved that as the time step goes to zero these solutions converge up to extraction towards a weak solution to the free boundary model.
