Reliability Estimation for Stochastic Flow Networks with Dependent Arcs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Reliability Année : 2023
Estimation de la fiabilité des flots stochastiques avec arcs dépendents
The Creation and the Destruction Processes (CP and DP) are the basis of many efficient Monte Carlo methods for estimating the unreliability of highly reliable networks on both, the static and the stochastic flow network models, for the case of independent components. Some of these methods are based on the Splitting variance reduction techniques. Due to the Splitting basic mechanism, they operate over CP. Here we propose a Splittingbased Monte Carlo method, using the Marshall-Olkin copula for the case of non independent components. This proposal operates on the DP, because the Marshall-Olkin copula model over networks is quite related-and somehow similar-to DP, which is unusual but here necessary. Before addressing the proposal, the article presents a review of the methods based on CP and DP. At the end, a comparative experimental analysis shows the efficiency of the proposed approach.
GR-IEEE-TonR-22.pdf (382.8 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03895999 , version 1 (13-12-2022)
Hector Cancela, Leslie Murray, Gerardo Rubino. Reliability Estimation for Stochastic Flow Networks with Dependent Arcs. IEEE Transactions on Reliability, 2023, pp.1-24. ⟨10.1109/TR.2022.3178413⟩. ⟨hal-03895999⟩
19 Consultations
55 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
