On nonlinear robust state estimation for generalized Persidskii systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2022
A state observer is designed for a class of generalized Persidskii systems with nonlinear measurements, state disturbances, and output noise. We assume that all nonlinearities are diagonal and belong to a sector. The robust stability and convergence conditions for the estimation error are obtained by applying the theory of input-to-output stability. These conditions are established in the form of linear matrix inequalities. We provide numerical examples to demonstrate the efficacy and performances of the proposed observer.
estimation_journal_aut.pdf (1.16 Mo) Télécharger le fichier
hal-03903300 , version 1 (16-12-2022)
Paternité - Pas d'utilisation commerciale
Wenjie Mei, Rosane Ushirobira, Denis Efimov. On nonlinear robust state estimation for generalized Persidskii systems. Automatica, 2022, ⟨10.1016/j.automatica.2022.110411⟩. ⟨hal-03903300⟩
11 Consultations
28 Téléchargements
